Convert array of strings to array of numbers
How do I convert an array of strings (that are numbers) to an array of numbers so I can find the maximum value? I've tried using the code below in the snippet but my numbers are coming out way too large.
Message 1 of 9
(6,378 Views)
Accepted by topic author Eric1977
It is much easier than that.
Tim
GHSP
Message 2 of 9
(6,376 Views)
Thanks, aeastet!
Message 3 of 9
(6,373 Views)
You are welcome
Tim
GHSP
Message 4 of 9
(6,364 Views)
What is the tool that you used to do that (the one icon that say 999).  This is just a picture, so I can't actually find what that is called or what pallet it is in.
Message 5 of 9
(6,285 Views)
Decimal String to Number. Should be on the Programming - String - String/Number Conversion...at least thats where mine is. Smiley Wink
Message 6 of 9
(6,280 Views)
Decimal String To Number Function
(Note that if your values are not integers, you might want to use this instead)
Message 7 of 9
(6,273 Views)
BEWARE that unless these are interger strings, you want to use FRACT/EXP String to Number!!!
[Edit] Okay, so I'm a slow typer...  😉
Bill
CLD
(Mid-Level minion.)
Message 8 of 9
(6,271 Views)
It's actually not "just a picture".  It is a snippet.  If you drage that image from Internet Explorer to your block diagram, it drops it as code.
Message 9 of 9
(6,253 Views)
