Convert byte array to specific data type
Hi there
I have a strong from TCP port being read, which I'm converting to a byte array. Now this byte array has various types of data in it. I need to convert specific bytes to different data types. For eg.
4 bytes to unsigned INT
8 bytes to float
8 bytes to unsigned long long etc.
Can someone please help me with the unpacking of the bytes.
Shall be highly grateful
Message 11 of 21
(4,530 Views)
This message is a year and a half old.  You probably should have started a new thread.
What is "a strong"?  Maybe you meant "string"?
Did you try following the advice of earlier messages in this thread to use the Typecast function?
If you need more specific help, then you should attach a VI with the string saved as a constant, and the list of data types you need.
Message 12 of 21
(4,525 Views)
We would also need to know the specific format/protocol for the data your are receiving. It is defined somewhere. Without that are advice would be very general.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 13 of 21
(4,517 Views)
I recommend using Unflatten From String to decode your data.
Message 14 of 21
(4,510 Views)
Hi Mark
Thank you for your revert. It's a huge data packet wherein the data type varies depending on the packet type and hence needs to be unpacked accordingly. For now I just need to know if I have a 8 bytes of UINT (an array) , how do I convert that to a double value?
Message 15 of 21
(4,497 Views)
Hi
Thank you so much for your revert. Yes that's a typo. I meant "string". My bad.
I'm aware of the type cast function, just that not too sure of how to use in this case. Could you please help me with an example?
I have 8 bytes of UINT byte array which I need to convert into a double float.
Message 16 of 21
(4,501 Views)
Hi crossrulz
Thank you for your revert. Since it's a large chunk of data, I'm not too sure how would un flatten from string be helpful. I converted the string to an UINT byte array so that I can parse the bytes (different types and lengths of packets) and unpack them accordingly. Could you please help me out with this?
Thanks a ton!
Message 17 of 21
(4,500 Views)
Hi sakshi,
typecast or Deserialize your 8 U8 bytes:
Message 18 of 21
(4,489 Views)
What the heck is a "revert"?
Message 19 of 21
(4,479 Views)
@sakshi14 wrote:  Since it's a large chunk of data, I'm not too sure how would un flatten from string be helpful.
You can do all of the conversion with just one call by unflattening a cluster.  I also prefer to use the Unflatten From String since it has an option for Endianness (how the bytes are arranged in a multi-byte data type).
Message 20 of 21
(4,459 Views)
