Convert cluster to readable string and string to data, but not UTF-8?
@paul_a_cardinale wrote:
And even if so (data to string), is there a way to write the text back to a variant (string to data)?
Why would you need to do that?  Just use the original data.
You'd need that if you store the text in a (human readable) file or database, or transfer it as text for other reasons.
You could use JSON or XML for this, but serializing is never going to be easy.
As I understand, the MGI solution is pretty much an OoTB solution.
I'd try to keep the data binary, but sometimes you simply want strings.
Message 21 of 21
(330 Views)
