Convert .doc to .html file
I want to convert and save .doc file into .html file. What command we can use in system exec.vi?
(3,546 Views)
This is a Windows question, not LabVIEW.  Some software wrote the .doc file (Microsoft Word?) -- you need to open it in that routine and see if there is a conversion to HTML, or use some other Software to do this for you.
You might, in principle, be able to do this in LabVIEW with the Report Generation Toolkit, which has some Word abilities and can generate HTML Reports.  But I would think a Third Party (or Word, itself) solution would be simpler.
Bob Schor
(3,516 Views)
this not exec.exe, but you can open word and "save as" via ActiveX
(3,507 Views)
