Convert double precision float string to a number
I am a newbie with Labview.
I have a GPIB link with a vector voltmeter and I receive the data as a double precision float string (IEEE standard 754-1985). I would like it to be recognized as a number, but I can't find the proper conversion function. The string to convert is 8 byte long. Does anyone have an idea how to do it? Thank you!
(4,450 Views)
can you post some sample data and what you expect to convert it into???
(4,442 Views)
Asumming your data is big-endian, you should be able to simply typecast it to a DBL (see attache LV 7.0 example).
(It is possible that your DBL string is little-endian, in this case it will be slightly more complicated. Let us know ;))
Message Edited by altenbach on 05-27-2005 04:49 PM
(4,439 Views)
It works perfectly! Thank you very much for your time (both of you)!
Karine
(4,411 Views)
