Convert float to rational
The TIFF tag header protocol requires a data type I am not really conversant with, the Rational Data type: http://en.wikipedia.org/wiki/Rational_data_type
I need to convert double precision numbers to this data type, e.g. 24.5 needs to be a ratio of two integers: {49,2}. Is there an existing LabVIEW algorithm to perform this operation? All my NI searches keep resulting in Rational ClearCase or Rational Array interpolation. I seem to have found a lot of the theory behind this: http://stackoverflow.com/questions/95727/how-to-convert-floats-to-human-readable-fractions
But, is this implemented in labVIEW already, or should I implement the above-referenced c-code?
Mello
Data Science Automation
CTA, CLA, CLED
SHAZAM!
Message 1 of 10
(8,926 Views)
That implementation is not in LabVIEW. Perhaps you may wish to post a suggestion to add it to a future release of LabVIEW.
If you have C code that will do it then you can call it using Call Library Function Node . You'll either need a DLL or you'll need to create one. Or, you can just convert the code to LabVIEW.
Message Edited by smercurio_fc on 02-24-2010 11:01 AM
Message 2 of 10
(8,919 Views)
Thank you smercurio, I think I am going to go with the workaround/kluge method of multiplying by a power of ten and truncating:
23.5  => {23500, 1000}
I will add a suggestion that a more elegant solution be made part of the NI math or numeric palettes.
-Mello
CTA, CLA, CLED
SHAZAM!
Message 3 of 10
(8,897 Views)
Maybe you can make use of Altenbach's fraction code in the last post in this  link can help you.
cheers
David
Message Edited by David Crawford on 02-24-2010 06:09 PM
Message 4 of 10
(8,890 Views)
Accepted by topic author Mellobuck
This should be possible if you have MathScript available.
 see attached ( LV 8.6.1)
Message Edited by Phillip Brooks on 02-24-2010 02:33 PM
Message 5 of 10
(8,872 Views)
Thanks Phillip!
A Matlab user such as myself should have thought of that method 🙂
CTA, CLA, CLED
SHAZAM!
Message 6 of 10
(8,860 Views)
Glad to be of help. KAPOW!
Message 7 of 10
(8,857 Views)
Neat. Didn't know that function existed in MathScript.
Note that for LV 2009 one requires a separate license for MathScript. There was a big long debate about this when 2009 was released. Every bitched and moaned. It was fun reading. Not so much fun for those who had to shell out more cash for it though.
Message 8 of 10
(8,824 Views)
I was curious if there were other ways to do this and found that Scilab combined with the LabVIEW Gateway works quite well. The 'rat' function is available in Scilab; Scilab and the LabVIEW gateway were both easy to install...
http://www.scilab.org/products/other/labview_gateway
Message Edited by Phillip Brooks on 03-04-2010 08:29 AM
Message 9 of 10
(8,736 Views)
Since LabVIEW has a vi to return the greatest common multiple, it's not hard to make a vi to get to fractions. This snippet solves a similiar problem of converting the floating point number to string whole number plus a fraction.Number to string with fraction.png
Message 10 of 10
(7,875 Views)
