Convert hex (or byte??) to double
I am terribly sorry but still no lack with that.
I guess you mean to make a formula node?
what kind of input do i provide?
the value i.e. C5D1 is a string as i get it from the instrument.
how do i convert it to a value that i can do calculations with?
i tried "Hexadecimal string to number" and then "Mantissa & Exponent" but i get wrong values.
please help!!
Message 11 of 22
(2,277 Views)
Hi 21232,
I would convert the string you get into an array of U8. Then pick the needed bytes and do the calculation with them.
I never told to use "Mantissa&Exponent". I gave you formulas to calculate them! You can do the calculation using formula nodes or (my preference) using standard math functions. Try to solve this right now or wait another 2 hours - then I get access to a computer with LabView...
Message 12 of 22
(2,273 Views)
http://en.wikipedia.org/wiki/Single_precision_floating-point_format
Compare that to your 2-bytes and you'll see quite some similarities. The 1st byte is identical between the two and the 2nd byte should be converted to U16, multiplied with 2 (or bit shifted left 1) and insert an empty byte in #2. That should give 4 bytes that can be type converted to a Single Float. (If you really want it in doubles you can do the a type convert again or modify the routine to 8 bytes)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 22
(2,267 Views)
ok i converted the string to an unsigned byte array but i am in a dead end still .The array reads 99 53 100 49 .
i will wait for your sollution GerdW.
thanks a lot.
best regards
thodoros
Message 14 of 22
(2,262 Views)
Example of 2 byte conversion.  Disclaimer this was a quick example, there may be better logic out there.
Dan
Herrlin
Just trying to spread the LabVIEW love.
Message 15 of 22
(2,261 Views)
hi herrlin,
thanks for the solution but one quick question,
how do i convert a hexadecimal string to an input for your code
C5D1 is a string that i did not manage to convert to input for your code.
also where is the function for the exponential of 2?i couldn't manage to find it but i did it in a formula node.
cheers
thodoros
Message 16 of 22
(2,246 Views)
Power of 2 was under Mathematics\Elementary & Special Functions\Exponential Functions directory. Also, once again this is a quick example.
Herrlin
Message 17 of 22
(2,242 Views)
thanks it works perfectly!
and for a 4 byte number?
i.e. CAEF5DCE what changes should i do?
cheers
thodoros
Message 18 of 22
(2,228 Views)
Hi 21232,
as you now have the code for 2 byte FPL and the description how to calc 4 byte FPL don't you want to learn LabView and change the given code to fit your needs on your own???
Come on, give it a try!
Hint: finding functions is easy using quickdrop <Ctrl>-<Space>
Message Edited by GerdW on 03-09-2010 05:55 PM
Message 19 of 22
(2,220 Views)
ok i will
thanks
i am still trying to figure out what the first code does though.
i have zero experience in hexadecimal data manipulation.
i will give it a go but i hope if i don't manage you could give me a push.
thanks again
thodoros
Message 20 of 22
(2,215 Views)
