Convert hex string to number
So are you getting a string with those characters in it?  If so, then you need to use Hexadecimal String to number.
If not, attach a VI where you have your incoming data saved to a control as the default data.
Message 11 of 14
(2,403 Views)
What if I want to convert my input HEX data in to U32 ?
Message 12 of 14
(2,382 Views)
Hi Karan,
Just do that!
Do you mind to provide an example VI with typical data as received from your BT device?
Message 13 of 14
(2,379 Views)
Please clarify what you mean by "HEX data".  Are you getting raw data (not readable in a text editor) or ASCII characters that look like Hex data in a text editor?  An example VI with a sample data set as the default for the input control will help A LOT.
Message 14 of 14
(2,371 Views)
