Convert image to one dimensional radial array
Hi!
I am sorry but I won't have again a pc with LabVIEW before tuesday, so I can't convert the VI I posted righ now... Smiley Sad
MikeNuke, PhD
Politecnico di Milano
Department of Energy, Nuclear Engineering Division
Message 11 of 16
(1,894 Views)
I am pretty sure this is exactly what I want! I will test it out on the instrument and see how it works in comparison to the current implementation. Thanks so much guys! I will get to rewriting 😛
Message 12 of 16
(1,878 Views)
You're welcome, please mark Bob's post as a solution as well, it was his idea after all!
Message 13 of 16
(1,876 Views)
Oh i forgot to ask, with Greg's example it should be possible to use loop parallelism, which would speed up the code significantly right?
Thanks!
Joe
Message 14 of 16
(1,873 Views)
It is possible, but when dealing with arrays of only 56 elements, the overhead required makes it not worth it!
Message 15 of 16
(1,859 Views)
Well the array is 56 x 56 if that changes anything, but it is good to know the parallelism has overhead associated with it 🙂
Message 16 of 16
(1,845 Views)
