Convert jpg to ASCII for Zebra printer ZPL code output
I am looking into this now. There is a preview option on the web pages of the printer. It is under the "Directory Listing" option. Once there you can "Create a New Script" which will allow you to preview the label format. I am investigating how you could do this automatically.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 12
(5,407 Views)
Hi Raydur, i guess I'm bit late) But currently I'm ecnountering the same issue with long loading png img. I've also sent converted to ascii byte array of my png img to the printer by ~DY command and reading it from memory to print using ~IM command with specifying E memory and image name like 'xxx.png'. And this process takes forever to finish. Please, can you describe how you converted png to grf so that it will load faster?
Message 12 of 12
(657 Views)
