09-05-2008 05:12 AM
I have an old program, written on LabView6.0 which I need to convert to LabView8.6 .
It works with most of the VIs, but some of them have problems.
They use subVIs from NI.vi.lib and I don't know how to convert them.
Thanks!
fluemle
09-05-2008 08:19 AM
09-05-2008
09:17 AM
- last edited on
09-05-2008
10:59 AM
by
Support
Hey Dennis,
sorry for the incomplete informations. Meanwhile I made some further steps to solve my problems. But there is still one. As I posted, I have an old working programm from Labview6.0 and I tried to copy the code on a new computer with labview8.6.
I was able to open some of the VIs but had problems with some others. The VIs I had problems with needed the "Generate Report Set Modified Data" VI from the "vi.lib\utility\NIReport.llb". So my first step was to copy the vi.lib from the old programm and tell the VI which needs the Generate Report Set Modified Data VI where it`s located.
With this information the original VI opened but still has some errors. There is a broken wire between and the help says that I have connected to terminals of different data types.
The original VI is "Wordfile initialisieren" and the subVI is "Generate Report Set Modified Data". I attached the two files so maybe you can help me.
09-05-2008 09:22 AM
09-05-2008 09:23 AM
09-05-2008 09:57 AM - edited 09-05-2008 09:58 AM
Also, isn't it illegal to post NI toolkits that you have to buy? ![]()
Unless, of course, NI has decided that it's so old, it's OK. Still, you would need their permission to post it.
