Convert logging library from LV8.0 to LV6.1
Hi all
Months ago I submitted a logging library in the example code area. As always, this library was improved and now I got an email, asking if I had it for LV6.1.  Unfortunately, I just have it in LV8.0. So could anybody out there convert the attached library and example of usage vi to LV6.1? Of course you can use it as well, if it is helpful for you.
Thanks in advance.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(5,915 Views)
The attached ZIP file contains the 6.1 version of your code. I have opened it in LabVIEW 6.1 and corrected the errors with the error dialog typedef control, so hopefully it should still work as expected.
Regards
JamesC
NIUK and Ireland
(5,900 Views)
Thanks for the conversion - I was the guy that asked for it!
(5,895 Views)
Glad to be of help
James
(5,890 Views)
