Convert numbers 0 to 6 into Monday to Sunday
I created a 2D array and with an Index Array I am extracting information from each row, but instead of selecting rows 0 to 6 in the Front Panel,  I need to display the days of the week. Any ideas to help me please?
I am trying with a Format Value Function, but it is not working for me:
Thanks in advance for suggestions!
George
(2,515 Views)
Accepted by topic author GeorgeDuncan
I believe the %w code just takes a date/time and outputs the index (0-6) which is not what you want.
There may be a fancier way to do it, but I would just make a constant array of strings, where each string is the text for the day of the week and use the index you've already got to select one of those and output it.
(2,484 Views)
An enum would work too.
Former Certified LabVIEW Developer (CLD)
(2,464 Views)
Thanks a million, this worked perfect!!! 😀
(2,410 Views)
