Convert numeric into string, but whitout the non significatives zeros in the decimal part ?
With the "number to fractional string", we can't automaticaly adjust the precision depending of the non significative zeros we can find at the end of the decimal part. For example, I want a precision of 3 decimals. So if my number is "3.1234", I want a string like "3.123", but if the number is "2.1" I want a string like "2.1" and not "2.100".
Does someone have the solution ?
(3,016 Views)
What version of LabVIEW are you using? With 7, you just use the format into string function and use %#.3f as the format string. The # symbol says to remove trailing zeroes.
(3,016 Views)
I use LabView 6.1
(3,016 Views)
After your conversion to a string, try a match pattern function with 0+$ as the expression and use the before sustring output.
(3,016 Views)
It works, except the "dot" if the number is "4.000", it writes "4." instead of "4".
(3,016 Views)
Then do another match pattern to remove the ".".
(3,016 Views)
Ok, thanks, now it works perfectly !!!
(3,016 Views)
