Convert pdf into text
I tried this method: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kJtvSAE&l=en-IN
but getting below error, what could be the issue.
(2,266 Views)
Did You take a look at the documentation for the PDFBox at https://pdfbox.apache.org/2.0/commandline.html ?
What happens when You open a command line and directly call
java -jar path/to/pdfbox.jar ExtractText path/to/pdf.pdf path/to/text.txt
(2,232 Views)
