Convert project labview v2012 to v2018
I would like to convert my project in labview v2012 to v2018, what do I need to do? Ps: I tried to open the project and several files were not found.
Message 1 of 16
(5,108 Views)
Which VIs?
maybe you need some toolkits etc?
Message 2 of 16
(5,107 Views)
Are here!
MsgMsgVi´s.Vi´s.
Message 3 of 16
(5,097 Views)
You need library for Agilent 34401
Message 4 of 16
(5,093 Views)
Follows warning file.
Warning when I open the project.Warning when I open the project.
Message 5 of 16
(5,084 Views)
If you save your proj in 2018, you'll update vi.lib in 2012 folder and can't work with Agilent in LV2012.
You need install library for Agilent 34401 for LV2018.
Message 6 of 16
(5,071 Views)
I understood, my vi.lib version is 2012 and I need to upgrade to 2018. But how do I do this? I'm looking at google on Agilent 34401, but I can not figure out what it's all about. Could you send me some link for research and / or reading.
Message 7 of 16
(5,069 Views)
Message 8 of 16
(5,064 Views)
A regular install is best because sometimes there are things other than code (palettes, etc.) that are either needed or at least helpful.
However, a short-term thing that might help you get by is to copy the respective .llb files from the LV2012 installation folder hierarchy into the corresponding folder in the LV2018 hierarchy.  The Agilent instrument code is being found under the instr.lib folder while the other missing item is somewhere under user.lib
No guarantees, but I've found that such moves often work.  (Note: the first time you close any of these vi's from your 2018 project, you'll be prompted to save.  Do it, though I'd probably first check to make *sure* the save location is under the LV 2018 hierarchy rather than 2012.  It very likely will be but it doesn't hurt to make sure.)
-Kevin P
Message 9 of 16
(5,061 Views)
I still have questions about using this program, what should I do exactly?
Message 10 of 16
(5,042 Views)
