Convert "hex string" to hex
I have a vi reading in from a VISA Read a string of the format;
AAAA,BBB,CC,DDD,EEE,FF,GGGGG CRLF
The 'FF' should be a hexadecimal value, but when read in it is in string format.  A simple string conversion to hex (using 'hex_bin_oct_string_conversions_LV85.vi', for example) does not work, as that results in an incorrect hex value.  For example, 'FF' might equal 00.  When 00 is converted with the string conversion to hex, the result is 3030.  I need to convert the string '00' to a hex value of 00.
Any thoughts would be greatly appreciated.
Message 1 of 12
(5,109 Views)
Go to the String->String/Number Conversion palette.  In there you will find the Hexidecimal String to Number function.
GCentral
Message 2 of 12
(5,091 Views)
Thanks for the feedback, however, using that function 00 is then represented as 0.  I suppose the solution is to convert the characters individually?
Message 3 of 12
(5,087 Views)
You need to be more specific!
Are the commas and spaces you are showing real delimiters? is "CRLF" four characters or two characters?
Are the fields hexadecimally formatted strings or binary strings?
What is the desired datatype after conversion?
It would be best of you could attach a small VI containing a typical string as diagram constant. Easiest would to to run your VI with a string indicator for the received string. After that, stop the VI, right-click the terminal and "create constant". Place the constant into a new VI and attach it here.
Message 4 of 12
(5,082 Views)
Yes, the numeric value of a "00" string is 0. If you want to show it as hex, check the properties of the numeric indicator.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 12
(5,066 Views)
Okay, so using the Hexadecimal string to number function, I was able to convert to binary.  See attached vi.  Had to separate into individual characters, process, then concatenate strings.
Thanks for your feedback.
Message 6 of 12
(5,065 Views)
You know you can use the Scan From String just as easily.  And if you make the output a U64, you can handle 16 hex digits at a time.
GCentral
Message 7 of 12
(5,060 Views)
Unless I'm missing something, which I probably am, that version of code results in 00 = 0000, not 00000000.  It's dropping zeros.
Message 8 of 12
(5,053 Views)
try a format of "%04b". (I would probably use a lookup table instead)
Message 9 of 12
(5,047 Views)
The main problem is that you code is not scaleable, and actually returns a truncated string for your default input of "ABC" (same as for "AB"!)
As I said, a lookup table is more reasonable, and it can scale to input strings of any length. There is even a safeguard to substitute "xxxx" for any illegal input characters.
Message 10 of 12
(5,032 Views)
