Convert rotation to rpm in vi
Ha, love it. Been helping Uddy for weeks and the only kudos i get is from Jeff.
Cheers mateSmiley Very Happy
"Everything should be made as simple as possible but no simpler"
Message 21 of 24
(1,048 Views)
Hi Lucither,
Sorry about the kudo's. I'm still learning the works and wasn't sure if I could add them at anytime or when I was finished. I believe I added some. I greatly appreciate all the help and advice you have shared. I've only had a fews minutes to look at the setup, no new info yet.
Thanks again for the help,
Dan
Message 22 of 24
(1,028 Views)
Hi Uddy,
Dont worry, i was only teasing. Quite a lot of people, including myself to begin with, are unsure about the 'Kudos' thing.
If you have more probs with you vi dont worry about tidying it up before you post. It is always good to try and keep your vi's neat and organised but if yours has got out of hand i should still be able to follow it enough to help you. You can then set about tidying it up once we have it working correctly.
Rgs,
Lucither
Message 23 of 24
(1,016 Views)
This thread has some interesting discussion on Kudos
Also the FAQ (Press the Help link next to the dashboard link)
We also Have tags to some Forum Tips (From My Tag Cloud)
Message 24 of 24
(1,003 Views)
