Convert string number to a string with 6 digits
For example. I want to convert a string 6 to 0000006. I used the format specifier %07d. By I am getting 6000000 instead of 0000006 . It would be great if I get a solution for this.
Skaria Roy
LabVIEW Enthisiast
(4,908 Views)
Try this one: %0#7_13g
(4,902 Views)
I'm assuming you are starting with a string representing an integer, and want a string of 7 digits, padded with (leading) zeros.  The solution is very simple -- Scan from String (to convert the String into an I32) and wire that directly into Format into String with a format of %07d.
Bob Schor
(4,876 Views)
Here are a couple of options for you.
(4,851 Views)
