Convert to Signed Decimal
Hello All,
I am receiving the following delimited string over GPIB.
ST4;TA246;TD252;AF15;ME3;SP1850;SP2250;SP365136;MS     2
The instructions to interpret this string tell me convert to Signed Decimal when dealing with negative temperatures. The value I am trying to convert is 65136 which I supposed to be -40 Degrees C.
How can I do this in Labivew?
Can anyone point me in the right direction.
(5,411 Views)
Hi Andy,
convert the string to an U16 value, then convert that U16 to an I16…
(5,398 Views)
Accepted by topic author AndyTT
In addition to the convert to a U16 and then type cast to I16, it also looks like you will need to divide by 10 to get your actual temperature.
(5,393 Views)
Isn't it enough to parse the string to I16 instead of parse U16 and type cast? Or it'll 'safe out' at +32k instead?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(5,350 Views)
It will "safe out" to +32k (just tested to make sure).
(5,342 Views)
But as Gerd already suggested, converting to I16 is the same as the typecast to I16, but simpler and less code (works for all integers if the number of bits does not change, of course).
(And if you only need the blue indicator, setting the indicator to I16 would even be sufficient, but you get a pretty coercion dot :D))
(5,305 Views)
