Convert txt-file
Hey,
I have an easy question but for me it is quite difficult to find a solution. I am new in Labview. My question goes as follow:
When you have a txt-file and you want to read it in labview. How do you do that?
This txt-file exits off numbers. You can see an example of the txt-file in the appendix. After reading the txt-file in labview, I want to put the numbers in an array. So the first column of the array  contains numbers that you can find in the first column of the txt-file. How can you do that?
If you can help me, thank you very much!
Kind regards,
Nicolas
Message 1 of 8
(3,904 Views)
Use the Read From Spreadsheet File.vi. Look at the LV help for how to use this function.
note: with a png it is not possible to determine what are the column separators, the txt file would have been more usefull.
Ben64
Message 2 of 8
(3,899 Views)
       Try using "Read From Spreadsheet File.vi".
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 3 of 8
(3,895 Views)
I have read your explanations, I have try it, but I don't understand it. Labview is something new for me. So can you please give me a little bit more explanation about the program who reads the txt file in array?
Is it possible to describe step by step how I need to work?
Kind Regards,
Nicolas
Message 4 of 8
(3,863 Views)
Hello Nicolas,
Can you post an example (in txt-format) of the spreadsheet file you want to read?
Have you already went through this page?
http://www.ni.com/gettingstarted/labviewbasics/
This will learn you some LabVIEW basics which can be very useful for a new LabVIEW programmer.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 5 of 8
(3,844 Views)
Use Read from spreadsheet file and give input to this function as your txt file.
Message 6 of 8
(3,840 Views)
You need:
Path control (points to the text file)
Read from spreadsheet file (looks like tab separated)
Index array, to get your 1st column
Array indicator to show your result.
Done. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 8
(3,815 Views)
You also would need some wires... 😉
Kind Regards,
Message 8 of 8
(3,762 Views)
