Convert unsigned bytes (U8) to time date stamp.
From a CAN device I have the date and time as a series of seven unsigned bytes (U8) as follows:
Century         example        20
Year              example       10
Month           example         4
Day              example        26
Hour             example       20   (8:00 PM)
Min               example       20
Sec               example         1
which would be:
            4/26/2010
            20:20:1
What is the best approach to convertng these seven values to a date/time format for display purposes only?
Thank you.
(3,685 Views)
Accepted by topic author chuck72352
Chuck,
Here's a couple of ways to do it, but sure there are others.
The first for numeric inputs or concatenate to a string with second.
Hope one of these does what you need.
*Edit - added combining or Century & Year
Message Edited by jrjones on 04-25-2010 10:40 PM
LabVIEW 5.0 seems so long ago...
(3,680 Views)
Your century/year manipulations are incorrect.  The result of 20 and 10 gives you 5130.  Maybe its a time machine.
What you need to do is basic math, multiply the century number by 100 and add the year.
(3,674 Views)
Raven,
You are correct, that combination is just WRONG.
Thanks for the catch....
I guess it's time to go to bed; I'm not paying attention to what I'm doing.
(3,669 Views)
