Convert vi from LabVIEW 5.0 to v.8.2
Hello-
I am trying to open a subVI in LabVIEW 9.0 but it was written for v. 5.0... someone told me that if I open the vi in a version before 8.2 and save it, then I should be able to open it in 9.0. I don't have any version before 9.0 so he suggested that I post the file on this forum... I have attached the subVI so if someone could please convert it (who has a version of LabView older than v. 8.2) it would be much appreciated!
Thanks!
Message 1 of 11
(4,924 Views)
The two VI's are nearly identical.  I did a bit of cleanup on them.  I don't have the SBI subVI's so you may have to relink to them.
Message 2 of 11
(4,916 Views)
Hi NEGR,
as long as you don't give us the missing subvis it's pretty useless to convert the vis...
(Now in LV7.1)
Message 3 of 11
(4,913 Views)
Thank you both! In order for the vi to open I also need a few more files converted so if either of you has the time that would be great! Thanks!
Message 4 of 11
(4,869 Views)
Here they come in LV7.1...
Message 5 of 11
(4,865 Views)
Please convert for me file Labview made from Labview version 5.0 below to open in LabView 9.0
Thank!
Message 6 of 11
(4,755 Views)
Hi Hoa,
here you go (in LV7.1).
You should consider some redesigns/optimizations for this little vi. And remove the vi.lib functions from the library!
Message 7 of 11
(4,746 Views)
Thank you very much for your help! Would you like to tell me the way to conver other file by myself?
I'm wating for your help! Thanks!
Message 8 of 11
(4,739 Views)
Hi Hoa,
it's easy:
Use a LV version that is capable of loading the vi Smiley Wink (like LV7.1)
Message 9 of 11
(4,737 Views)
I have just installed LV7.1, but I don't know how to convert files LV made from LV5.1 to open on LV 9.0. So Would you like to help me the way to convert? Thanks!
Message Edited by Hoa on 10-16-2009 10:39 AM
Message 10 of 11
(4,718 Views)
