Convert .vi to .exe
OK, so i just finished this program I have been working on.
I wanted to convert it to an executable file (.exe) so the user cannot tamper with anything.
Can someone tell me how to convert a file from .vi to .exe.
Note: If it matters, I have LabVIEW 7.1
Cory
Cory K
Message 1 of 14
(52,562 Views)
Coincidentally, the same question was asked just a few hours ago.
As indicated, you need the Application Builder. If you have the Professional edition of LabVIEW you should have it. The LabVIEW documentation explains how to do this. Have you checked it?
Message 2 of 14
(52,553 Views)
This will need the application builder which is not included in the base and full versions of LabVIEW. Please check if it is installed on your machine :
LV menu >> Tools >> Build Application or Shared Library (DLL)...
Message 3 of 14
(52,551 Views)
More information about Application Builder can be found here
If you already have Application builder, please follow the link below. And remember you must have your vi's in a project. Since Application Builder is only availible in Project platform.
Distributing Application with the LabVIEW Application Builder
Van L
NI Applications Engineer
Message 4 of 14
(52,494 Views)
Is there a way to reverse this process?
I have a .exe file which was written by a previous employee which we have no communication with any more. We need to make alterations to the file as the process has changed slightly, but the original project files were taken with them.
Regards
Message 5 of 14
(42,871 Views)
Regards
Nope.  Sorry.  That is like asking to take an EXE and generating C++ code from it.  Once a file is compiled code only, you can't get raw code back out.
Message 6 of 14
(42,853 Views)
Message 7 of 14
(42,840 Views)
@Rickvb wrote:
Hi n_wint
Maybe this is helpfull:
http://forums.ni.com/t5/LabVIEW/decompiling-2009-executable/td-p/991662
Interesting, but not helpful.
Jim
Message 8 of 14
(42,828 Views)
Explain why this could not be helpfull.
It was a simple forum search, is that it?
Message 9 of 14
(42,810 Views)
  1. The original topic asked how to convert a VI to an executable.
  2. The recent question asked if it was possible to reverse the process.
  3. crossrulz answered that it isn't possible.
  4. You linked to a discussion that also said it isn't possible
    It would have been helpful if you provided information that gave him, or brought him closer to, what he wanted.
Jim
Message 10 of 14
(42,788 Views)
