Converting 5.1 code to 8.5
I ran the program I posted.  I had in the same directory as the daa file and llb and simply ran the program.  It created the database.txt file.
Message 41 of 49
(1,621 Views)
How do I open the directories?
Message 42 of 49
(1,605 Views)
I don't understand your question.  How do you open what directories?
Message 43 of 49
(1,583 Views)
I want to make sure that the data file and the llb file are in the same directory the way you had them, but I'm not sure how to do that or even how to check that they are.
Message 44 of 49
(1,580 Views)
Are you refering to a working directory within LabView?
Message 45 of 49
(1,579 Views)
I have a directory on my PC for all the stuff I download from this site.  so, I had your stuff in C:\NIweb\Keithley Data File.  The llb was there, the data file was there, and the file I posted was there.  It doesn't have to be that directory structure, just whatever directory you have it in.  My program should work in any directory, you may just have to repoint it to the Keithley_Datafile migrated.vi.
Message 46 of 49
(1,569 Views)
Please forgive my ignorance, but how do I do that?
Message 47 of 49
(1,543 Views)
Hello again, I have one last question. Is there a way to extract the plots made by the VI?
Message 48 of 49
(1,505 Views)
The VI I posted will grab all the data from the datalog.  You can use it to get the arrays used for the graphs.  The VI I posted just used the data needed for the data text file for Excel, but the cluster contains all the data from the VI.
Message 49 of 49
(1,490 Views)
