Converting Binary to Decimal
I would like to convert 12 and 32 digit strings into decimal. Is there
a function in labview that does this? Does anyone have a vi (or sub-vi)?
I'm using version 5.1
Thanks!
-DG
dorian@jps.net
Sent via Deja.com
http://www.deja.com/
(4,184 Views)
use the %b format string in the scan from string function (string functions)
wrote in message news:95qec3$ekn$1@nnrp1.deja.com...
> Thanks!
> -DG
> dorian@jps.net
> Sent via Deja.com
(4,184 Views)
I've tried that, but to no success (I first convert the array into a
spread sheet string, and then use the scan from string function.
I did write a for while loop to do the conversion (basically using a
shift register and putting the converted bits into an array that's
built be the shift register, then adding them all up at the end).
The numbers look off. Does Labiew intrinsically change the bits like
from 0's to 1's when it's handling them?
Thanks.
-DG
In article <_g3g6.76071$o91.8024384@typhoon.nyroc.rr.com>,
functions)
> > I would like to c
there
vi)?
> > Thanks!
> > -DG
> > dorian@jps.net
> > Sent via Deja.com
Sent via Deja.com
(4,184 Views)
hmmm, now I don't understand the question, because scan from string with a
%b format surely does take a string like "101101101110" and convert it to
decimal number 2926. Could you give a specific example of the string and
the expected result
- Vinny Recca.
Thanks.
> -DG
> functions)
> there
> vi)?
> > > Thanks!
> > > -DG
> > > dorian@jps.net
> > > Sent via Deja.com
> Sent via Deja.com
(4,183 Views)
Hi Vinny,
Thanks for the posting Vinny (and Stu). I did figure it out. The
problem I initially had was that I had a 2-D array going into a for
loop. I can break the array into 1-D arrays and then change this into
an array into a string. No problems.
Thanks!
-DG
In article <3A823A6A.48BCB867@ix.netcom.com>,
with a
it to
and
> the expected result
> - Vinny Recca.
> > sprea
like
> > Thanks.
> > -DG
> > functions)
> > there
sub-
> > vi)?
> > > > Thanks!
> > > > -DG
dorian@jps.net
> > > > Sent via Deja.com
> > Sent via Deja.com
Sent via Deja.com
(4,177 Views)
If your string is all binaray numbers then you can use the from Decimal function
in the strings palette
in the Additionnal string to number functions (labView 5.0.1).
Eric Paulin
>I would like to convert 12 and 32 digit strings into decimal. Is there>a
function in labview that does this? Does anyone have a vi (or sub-vi)?>>I'm
using version 5.1>>Thanks!>>-DG>>dorian@jps.net>>>Sent via Deja.com>http://www.deja.com/
(4,182 Views)
