Converting Excel's Numeric Date to MM/DD/YYYY
I found a great VI in the Forums named "Excel Get Data Specified Field.vi".  This  vi will  read all the Excel data and put it into an array.  Works perfect!
The problem I am having is with Excel's Numeric Date Format.
Excel records dates as numeric values, and the user never sees the raw numeric date...instead the user sees MM/DD/YYYY.  MS Excel starts recording dates from 1900.
Examples of Excel's numbering:
"1" = 01/01/1900
and
"39176" = 04/04/2007.
I was hoping there might be someone that has already written this VI.  Or possibly, the solution is already built in Labview.  I am using LV 8.2.
Thanks for looking.
Doug
(5,995 Views)
Hi Dhubbell,
I did some searching around, and couldn't find anything that resembled what you needed.  I think this may be something you will need to code.  Most LabVIEW timestamp functions start from 12:00 a.m., Friday, January 1, 1904 and not 1900.  I have a feeling it could be done by using type casting or something similar.  If you do attempt to make the VI please post it for community use :).
Brian K.
(5,957 Views)
Hello Doug,
Excel can deal very well with "12:00 a.m., Friday, January 1, 1904",
go to  (my Excel is german)
Extras -> Optionen -> Berechnung -> enable option "1904-Datumswerte"
in an english Excel, it should be something like:
Tools -> Options -> Caculations -> "1904-Data values"
And when you divide the seconds through (24*2600) [the seconds of a day]
you are in business.
Now you can format the cell as time or data.
Stefan, Ulm, Germany
(5,788 Views)
