Converting Image into signal
Is it possible to see a signal representation of an image and display it into a waveform graph or something?
(3,044 Views)
what kind of signal ? & how do want to display?
Whats your exact requirement ? have you tried anything wrt this?
Better requirement sharing will get better response to your expected solution
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,026 Views)
