Converting Labview Front panel to PDF
Hi I'm trying to save LabView front panel to PDF format during execution time without using Acrobat distiller. I dont know how to proceed. Anyone can solve my problem?
Message 1 of 10
(7,600 Views)
Hi Hems!
What's the purpose of the saving? If you just need it to illustrate the layout of the front panel the easiest way seams to be to just knock on the "Print screen" and open it up in photoshop too modify it as you please....
Message 2 of 10
(7,588 Views)
If pritscreen is not enough powerfull for you, you can try "Snagit". You can capture windows with scrollbar, make movie if you want or get a text file from a screen capture.
By
Yann
Yann Falevoz
R&D Engineer, Instrumentation & Software
Message 3 of 10
(7,582 Views)
Take a look at CutePDF at http://www.cutepdf.com/Products/CutePDF/writer.asp
David
Message 4 of 10
(7,575 Views)
Hi
I developed a vi that generates a PDF file containing a front panel image.
It uses only pure LV, no external dlls or 'PDF-printers'
interested ?
Message 5 of 10
(7,529 Views)
Hi gnilsson
It is interesting......is it possible for you to post that program here...
Anil
Message 6 of 10
(7,525 Views)
OK
Here are a working demo
You can contact me at gnilsson2@msn.com
Message 7 of 10
(7,498 Views)
Hi.
I was interested in this vi but "image data to pdf" wont load (see attachment)
Message 8 of 10
(7,144 Views)
Hi AJG,
Have you tried saving the VIs to your desktop and opening up the test main.vi first? What you might have to do is do a mass compile to relink all of the VIs. In order to do this, Tools»Advanced»Mass Compile.... If not, my next suggestion would be to contact gnilsson, who created the VI is see if he can get you a newer version of the VI. I hope this helps!
Carla
Message 9 of 10
(7,103 Views)
Contacting gnilsson is going to be the only option since for security reasons I guess, he chose to save the llb without diagrams instead of password protecting the VIs in the llb.
Message 10 of 10
(7,098 Views)
