Converting Mac LV6.1 to Win LV2010, problems: "AI Read One Scan" and "AO Write One Update" to DAQmx
For your kind attention,
     As stated, I'm trying to convert a vi from Mac LV6.1 to Win LV2010 but I'm having problems around the "AI Read One Scan" and "AO Write One Update". Please note that I'm very much a LV novice. I know I have to go through DAQmx but I'm not sure how excatly to replace the input and output. The card is an USB 6221.
Here' s examples of input and output code, respectively.
http://imgur.com/a/H7NwJ
Note the two input channels and one output.
(My apologies, I don't know how to take a screenshot on the old Mac)
Thanks for your time,
-Vintage6.1
(2,372 Views)
-          You can check LabVIEW examples from Help>>find examples>>Hardware Input and Output>>DAQmx>>Analog measurements>>voltage for the acquisition
-          Or Help>>find examples>>Hardware Input and Output>>DAQmx>>Analog generation>>voltage for the output examples.
-          If you want you can check here additional information, because you were using before traditional DAQ, but I recommend you to start working from LabVIEW examples: http://www.ni.com/white-paper/4342/en
Regards
(2,357 Views)
