Converting Signal Data from Labview 8.2 To Excel Spread Sheet
I have a VI setup running four channels of data (measuring flow, pressure, voltage and amperage) and I need to know how to convert these signals to a Excel workbook.  Any help would be greatly appriceated, we are looking to start logging all of our data here soon.
Nathan
(2,763 Views)
If you have everything set up already so that you have a VI that produces a 2D array, just wire it up to the Write to Spreadsheet File function and you're all done.
If you're not that far along already, perhaps you could go into greater detail about what you have so far?
(2,755 Views)
