Converting Trial version to licensed version
My company is in the process of purchasing LabVIEW 2018 professional version.  While the project funding is in process, can I download and install LV2018 and use it as a trial version until the purchase order comes through, and will it be fully functional for some period of time?
If so, is it easy to convert it to the licensed version once the purchase order comes through?
metzler CLAD
(2,754 Views)
Accepted by metzler
Yes, to all your questions. I don't think you will be able to build an executable with the trial version but everything else will be fully functional. Once you get your license you simply need to activate it in LabVIEW and you will be good to go.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,750 Views)
LabVIEW Evaluation Version Limitations
(HINT: You can build applications - with caveats.)
Bill
CLD
(Mid-Level minion.)
(2,715 Views)
