Converting UDP VIs from LabVIEW 5.1 to 6
When I convert VIs I developed in LabVIEW 5.1 that use LabVIEW's UDP functions to LabVIEW 6, the connection ID converts to a TCP/IP network connection instead of a UDP network connection. Is there anyway to make it default to a UDP network connection?
Thanks.
Brian
(2,669 Views)
I just checked the UDP primitives in LabVIEW 6 and they return UDP connection IDs.
Perhaps you could open your LV5 UDP VIs in LV6, right click on the offending primitives that
are returning TCP/IP connection IDs and "Replace" them with new LV6 versions.
Alan
"Brian Bean" wrote in message news:506500000008000000081C0000-986697009000@quiq.com...
> Thanks.
> Brian
(2,669 Views)
