Converting a 1sec file for a continuous file
Well guys, I have a VI that read and write 4 voltages and 4 currents in each second... so it's generate a file with all those samples...
Now I made another VI that open that file and convert it to a continuos file. Example: In the first moment the file have like 60 seconds, but the graph show 1 sec then another second.... so i have to pass it 60 times to finish the file. In the new file I have a graph that show all the samples in 1 graph.
But my problem is... the first file have 60sec. the second one after I convert have like 70sec.
I have to know why the file is becoming bigger than the normal!
Can someone help me on that?
I will upload the screen shots:
This is the VI that convert the file
This one is the VI that read the new file:
The subVI's in convert VI.. is only some conversions that I made.... but the conversions isn't the problem, so I don't upload the subVI's.
Thanks!
Message Edited by EduU on 02-24-2010 06:52 AM
(2,722 Views)
It seems like the loop doesn't stop until you hit the stop button.  For the write file loop, you should have a condition that would terminate the loop when you finishing writinng.  Same goes to the other loop.
Yik
Kudos and Accepted as Solution are welcome!
(2,681 Views)
