Converting a delimited string to a string array
I have a string:
(no quotes)
"Aout,B,Cin,D,Etest".
I want to convert this into a 1D array of
Aout
B
Cin
D
Etest
I could not find a VI that does that. Best way to do this ?
Message 1 of 10
(13,424 Views)
The string to array function will do that.
Use a comma as the delimimter and a 1d-array as the data-type.
Ton
My LabVIEW Ideas
Message 2 of 10
(13,423 Views)
Thanks for the quick response.
I tried using the Spreadsheet string to array function, with the comma as the delimiter and %s as the format (as the documentation says). The input numeric double array (2D) is unwired. However, the output is still a double (orange) and wiring it to the search 1D array VI expecting a string array input produces a bad wire.
Am I using the wrong VI ?
Message 3 of 10
(13,415 Views)
Simply wire an empty 1D string array to the 'array type input'.
Message 4 of 10
(13,410 Views)
Accepted by topic author m-s
Had to wire a constant string array to the array type. Works now.
Thanks.
Message 5 of 10
(13,404 Views)
Then please mark Dennis' message as the solution to your question instead of your own message since he was the one who gave you the solution.
You can unmark yours by going to the option menu to the upper right of your message.
Message 6 of 10
(13,393 Views)
Please start a new thread rather than appending to a three year old thread which is marked as Solved.
When you do so, please be more specific. Your brief statement does not tell us much about the string, how many segments to split, or anythng else. You did not actually ask a question.
Lynn
Message 7 of 10
(12,047 Views)
You have to remember that this comes from a generation where they think that "That awkward feeling when you realize you can't write a complete sentence." is a complete sentence.
Bill
CLD
(Mid-Level minion.)
Message 8 of 10
(12,026 Views)
9 posts all to old threads, no value added, weird link for JAVA help in the signature...screams SPAM to me.
Message 9 of 10
(12,006 Views)
I didn't see the little link at the bottom.  Shows how effective the SPAM was.  I'm surprised that there wasn't ten other old threads that resurfaced also...
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(11,992 Views)
