Converting a text file into an array...
I'm trying to convert a text file like the one attached into an array. I've looked as some of the earlier examples but can't quite figure it out. ANy help or examples are truly appreciated.
(3,254 Views)
Easy enough.
LV 6.1
2006 Ultimate LabVIEW G-eek.
(3,254 Views)
oops, miss-browsed:)
(3,254 Views)
this little vi takes a string (or a text file) and creates an array element
for each element separtated by "separator". if you wire separator to a
string with just a space in it then it'll create an element for each value.
"dogbert03" wrote in message
news:5065000000080000002F970000-1042324653000@exchange.ni.com...
[Attachment explode.vi, see below]
(3,254 Views)
