I asked this in the Intrumentdriver/IVI forum:
> Is it possible to convert a LabView .ldd Instrument
> Driver into a dll that can be used with MAX and
> visual basic?
> I got the following problem. I'm using a Stanford
> DS360 UltraLow Destortion Function Generator, and
> would like to access it with the CwIVIFgen ActiveX
> Controll. In the driver database i found a
> instrument driver for LabView (ds360fg.llb).
> But its a llb file and i am not sure what to do.
> Is it possible to convert it?
> Is it possible to use it anyways?
I got the answer:
"If you have LabVIEW and the application builder, a dll can be created from it but it cannot be used as an IVI driver."
I do not have these applicat
ions, and i got the suggestion to post my problem here.
So i ask for help, can anyone compile the ds360fg.llb into an .dll for me? It would be really great.
The .lbb can be found at:
http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/7fa1f425e39a0fe3862568ab005fba7c?OpenDocument
Many thanks in advance!
Felix (gmbs@gmx.net)
