Converting binary input into a constellation diagram
Hi
I am using the MT Format constellation vi for generating a constellation diagram. The input signal is a multitone signal with 3 tones. I am not able to give this input to the vi. Is there any other vi that I could use? Also can I convert the multitone signal into a binary input for the vi.
Thank you.
(4,131 Views)
Did you ever find an answer to this? I'm having the same issue
(4,035 Views)
You need to be a bit more specific.
What signal are you trying to convert?  Can you post an example with data?
(4,024 Views)
Where did you get the MT Format constellation vi???
Is it part of an add-on pkg?
(3,991 Views)
It's part of the Modulation Toolkit>>Digital>>Visualization
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,989 Views)
