Converting concatenated string to array of strings
I'm trying to figure out how to convert a concatenated string such as "dude your,2,q"
Into a 1 d array that looks like:
dude your
2
q
As you can see, the way I have it coded, it outputs:
0
2
0
I'm confused.
What's a good way to do this?
(don't mind the words, I'm just using this to learn..... hahahaa)
(3,193 Views)
Accepted by nlis12
If you wire a numeric array as the default datatype for "spreadsheet string to array", it will give you a numeric datatype. You have to wire a string array as the default datatype, and at the output.
(3,191 Views)
I was closer than I thought.
Thanks!
(3,176 Views)
Try this:
=== Engineer Ambiguously ===
(3,172 Views)
