Converting data from u16 to i32
I can't find where in the functions palette these conversion functions are; the one right below the "THIS!" . Can someone direct me to them?
                                     THIS!
(5,870 Views)
It is in Programming>Numeric>Conversion
But the array in the snippet you posted does not need conversion to I32. Just make your constant a U16 type (Right-click > Representation > U16) much more efficeint
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(5,855 Views)
Found it, thanks!
That code I included was shamelessly copy/pasted from the ni website... twas the easiest way for me to describe what I was looking for.
(5,847 Views)
Dear  Scandia,
I am looking for how to convert data from U16 to I32.
How do you process? Could you please say it to me?
Dong
(5,319 Views)
Hi 11811800d,
This is a pretty old thread, but in any case, to convert between datatypes you can use the built-in nodes as described above, found under Numeric > Conversion.
The "To Long Integer" (with icon I32) will do what you want.
(5,315 Views)
Dear cbutcher,
Thank yours very much for your comments.
Dong
(5,309 Views)
