Converting from LabView 4.0 to 8.5
I have a Pico Technology TC-08 thermocouple datalogger (RS232). It has drivers for Labview 4.0 but I use Labview 8.5, which says it can't convert the drivers. From the help pages I have understood that there is separate software that can convert from Labview 4.0 to 8.5. Can anyone tell me where I can download or otherwise obtain this software?
Message 1 of 81
(8,690 Views)
Hi EKY,
if this program is rather small you can upload it here (as llb or zip) and someone (I Smiley Wink) will convert it for you.
If the program is large (or you have to convert older sources more often) you can order a conversion kit at NO charge from NI!
Message 2 of 81
(8,668 Views)
Thanks Gerd,
I'll try upload it. It would be nice if you convert it for me.
Message 3 of 81
(8,660 Views)
Hi EKY,
converted to LV7.1 - should be ok now Smiley Happy
But: there's a "missing dll"-error. You have to check this in LV8.5.
There is also no guarantee the dll will work with LV8.5 or maybe new operating system (from Win95 to WinXP or Vista?)
Message 4 of 81
(8,653 Views)
Seems to work now. Thanks.
Yes, the driver was made for Win95 and LV4.0. I use WinXP and LV8.5. I tried to upload the DLL with the LLB but the forum didn't accept .ddl extension.
Message 5 of 81
(8,647 Views)
Hi EKY,
the forum always accepts ZIPped files! But usually the dll isn't needed for conversion of vis to new LV versions...
Message 6 of 81
(8,643 Views)
I also need to convert a Pico example (for an ADC-16 datalogger) from LabVIEW 4.0  to 8.5. Anyone willing to do this for me? see attached and thanks...
Message 7 of 81
(8,414 Views)
Hi Bryon,
your vi contains just a DLL-call, but here you goSmiley Wink
Message 8 of 81
(8,402 Views)
Hi GerdW!
Could you convert me the following LabVIEW source please. If I try open it, I become an answer: that "It's to early to convert to the current LabVIEW version.
Gergö
Message 9 of 81
(8,330 Views)
Hi Gergö,
here it is for LV71.
Mike
Message 10 of 81
(8,327 Views)
