Converting images (png) to templates
I have hundreds of images (png) that I want to convert into templates to be used in "IMAQ Match Pattern 2".
I don't care about the angle the template was captured as and such, I will set them to default values.
Is there anyway to open the images (1 at a time) in LabVIEW and then save as a template image (png)?
Many Thanks,
A.
(3,072 Views)
ADL,
If possible I would store all of the images in a single file with incrementing file names.  For example have a folder of images called Images that contains img1.png, img2.png, img3.png ...
Then you can use a for loop to load each image and process it accordingly.  The example below shows how to load the images one a time, but does not do any processing:
Sam K
www.ni.com/support
(3,043 Views)
I think you missed my goal, I have 100's of images edited from paintbrush, but index to convert them to template images that can be usedin pattern match functions. A standard png cannot be used as a template for pattern matching, as the pattern matching file needs to contain extra information. What extra data is needed to e written into that template image, and is there a labviewvi to do that. A.
(3,030 Views)
ADL,
You will need to use the IMAQ Learn Pattern 2 VI.
http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_learn_pattern_2/
-Sam K
www.ni.com/support
(3,022 Views)
