Converting normal CAN dbc file to XNET compatible dbc file
Hello all,
I am trying to run a certain application on RT, which access a .dbc file which is there on its hard disk.
I transitioned to XNET now, and came to know that XNET has a different format which it supports, and is not compatible with older dbc formats. I was told by NI person to use NI XNET Database editor to deploy the dbc file, but I just want to copy the dbc file to RT which the XNET nodes should support.
Is there any way we can convert a CAN .dbc file to XNET compatible .dbc file?
Thanks.
FraggerFox
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(3,963 Views)
I have been wondering the same thing! This is terrible on NI's part, seeing as the .dbc is used so frequently.
(3,654 Views)
You can programatically deploy the .dbc file to RT and use it in your program
-FraggerFox!
(3,644 Views)
