Converting numbers containing coma's
How do I convert a string representation of a number that contains a Zero?
For Example:  8,148.23
In this example the conversion using the floating point converter returns 8 instead of 8,148.23
Message 1 of 11
(6,757 Views)
Hi emw,
remove the comma using string functions before you convert it to a DBL:
Message 2 of 11
(6,746 Views)
When I'm in a coma, I find it exceedingly difficult to convert numbers, even if they contain commas ...
BS
Message 3 of 11
(6,703 Views)
BS
New LabVIEW proverb?
Message 4 of 11
(6,698 Views)
Ok, now how do I control the Format of a number so that it does contain commas?
For example I want to make 186282.396 to read 186,282.396 instead...
Message 5 of 11
(6,090 Views)
You added to a 20 month old tread with a vague question. What do you mean by "read"? (Read from file? display in an indicator? Write to a file or table?)
There is no format statement to deal with "thousands" commas, but the math is trivial to translate any floating point number to such a string. Have you tried?
(Sorry, posting by phone)
Message 6 of 11
(6,080 Views)
i remember some time back that LabView had some kind of %###,###.###f format type that would insert comma's for powers of a thousand, but I can't remember the exact format of that format control.
Message 7 of 11
(6,012 Views)
Hi emw,
I don't think so.
Maybe your memory is mixed with Excel stuff?
Message 8 of 11
(6,009 Views)
How do I output Comma Delimited Formatted numbers (IE:  186,282.396) [American English Standard]
Which format control string provides that?  And this can vary between American English standards and European Standards where their comma's and decimal points are swapped characters.  They use periods for comma's and comma's for periods.
Message 9 of 11
(6,007 Views)
There is nothing built into LabVIEW to do it.  Someone may have created their own subVI.  I think I saw one time a Regex that will do that.
You should add a Kudo to this idea.  https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Visual-Aides-Numeric-Separators/idi-p/941273
Message 10 of 11
(5,995 Views)
