Converting rondom numbers array to boolian arry
I have 3×6 array of random numbers and i want to connect same array of boolian so when the number of random is 0 the corresponding value of boolia
(1,719 Views)
What have you tried?
(1,704 Views)
Hi Dalmar,
So there are 18 random numbers…
Which array of booleans?
What kind of "connection"?
Do you really expect a random number of being "zero"?
What should happen when the value is zero?
(1,700 Views)
Can you go back and finish the sentence so we see the entire question. thanks! It is best to attach your VI (or a simplified version).
Where do these random numbers come from? If they are generate by e.g. the dice, the chance of zero is zero! Are these number integers?
What should be output be? A 2D array of booleans? A single boolean indicating that all or some are zero? An array of indices of all elements that are zero? Something else?
(1,694 Views)
