Converting strings to the floating number and plotting
I have a question regardting converting string of numbers to the floating bumbers and plot for voltage vs. weight.
The load cell for the ADC resolution is 16 bits, and the voltage will be in between +-5 volts.
The problem, I have the most is converting the string of numbers to the floating numbers, in my case is the weight.1.jpg
(3,367 Views)
When you say "string of numbers" do you mean an array? What is the specific issue you are having? You seem to have orange wires running all over the place. Give a small example demonstrating the problem.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,357 Views)
Yeah, it suppose to give a plot showing voltage vs. weight .. I will try summarize what the block diagram means. Thank you for the help!
(3,350 Views)
