Converting text from file to numeric array
I have a problem i cant convert text from file to numeric array and i dont know why. I add my vi and txt file.
Message 1 of 27
(7,792 Views)
What have you tried?
Did i just not see the VI there?  Maybe i need more coffee.  I can't open it anyways.  Smiley Frustrated
aputman
Message 2 of 27
(7,781 Views)
Read from spreadsheet string will work for you.
aputman
Message 3 of 27
(7,756 Views)
I can't open it either, but on my platform I had to remove all the commas first.
Message 4 of 27
(7,753 Views)
Crisdragon / aputman,
I assumed the comma was the thousands separator, not the delimiter.
Message 5 of 27
(7,746 Views)
Are the commas delimiters or thousand separators?
aputman
Message 6 of 27
(7,743 Views)
There is a right-click option for the Read Text File to read lines.  Enable that and set the number of lines to read to be -1 (read all lines).  This will give you an array of your data points.  Then just use the Fract/Exp String To Number to get your data.
Message 7 of 27
(7,734 Views)
Thank you for the Read Lines tip Crossrulz 🙂 On my machine I still have to remove all the commas to get it to convert to number correctly.
Message 8 of 27
(7,727 Views)
As do I.
aputman
Message 9 of 27
(7,721 Views)
@aputman wrote:
As do I.
Same for me.  That is due to localization.  Some places use the comma as a decimal place.  Glancing at the data, I just assumed the OP was in one of those locals.
Message 10 of 27
(7,711 Views)
