Converting the global rectangle to ROI or bounding box or simple rectangle
I am using the labview vision utilities for my project and i need to get subimages by identifying different shapes like circle and rectangle. I am trying to identify traffic signs real time. so for faster processing i'm using "IMAQ Shape Match Tool VI". but it gives the output in the form of a global rectangle which i'm not able to use. Any suggestions would be appreciated.
(7,270 Views)
Why can't you pass your Global Rectangle to IMAQ Convert Rectangle to ROI (if you want to "convert the global rectangle to ROI")?
Bob Schor
(7,177 Views)
What you want to use the global rectangle or ROI for?
-If you are trying to do overlays: IMAQ IMAQ Overlay Rectangle VI is redily available http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_overlay_rectangle/
-If you are trying to extract there is IMAQ Extract VI http://zone.ni.com/reference/en-XX/help/370281P-01/imaqvision/imaq_extract/
-Region Of Interest Frequently Asked Questions (FAQ) : http://digital.ni.com/public.nsf/allkb/82C6023BCC87F5CA86256F38006D2C98
uday
(7,171 Views)
Accepted by topic author mana25
Thank you all for the reply.
And i needed the roi for the particle classification vi. But the global rectangle had only the coordinates of the upper left corner  and the lower right corner but no rotation.
So i unbundled em by name and then bundled it again using 0 degrees as rotation and then used the rectangle to roi vi. And the problem was solved. Alhamdulillah.
Again thank you.
(7,166 Views)
