Converting to binary and entering data on a table
So I'm trying to do 2 things:
1. Generate a random number, convert it to hexadecimal, and display it on a table.
2. Convert the hexadecimal to binary and display that on a table as well
Just started using labview so my block diagram is probably completely wrong
(3,728 Views)
Cant get data from numeric indicators onto table b/c indicators don't have an output for the wire..:(
(3,700 Views)
Accepted by topic author ABC123WEEEEE
Look at the Format Into String function.  You can define all kinds of formatting rules.  %x will take a number and format it into a Hex string.  %b will take a number and format it into a Binary string.  You will want to use the build array function to write to your table.
(3,687 Views)
Can you explain what %x and %b means?
Thanks!
(3,670 Views)
Use them in the format input.  Here is a link to the LabVIEW help about the Format Specifier Syntax.  I actually have this tacked up in my cube since I reference it constantly.
(3,654 Views)
