Converting to hexadecimal string
Hi everyone,
I am using Labview 2012 and receiving some data on my serial port that I want to convert to an hexadecimal string. I have attached a VI that only enables me to convert the first part of the chain but not the rest.
Does anybody know how to do this?
PS : I don't want to have just the incator displayed in hexadecimal, I really need to make a conversion of the string to be able to work around it after.
Thanks.
User
Message 1 of 8
(6,017 Views)
What is actual input and output needed. Share the actual real time data
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 8
(6,000 Views)
Here one possibility.
Regards, Jens
Kudos are welcome...
Message 3 of 8
(5,991 Views)
jg69 seems to have the answer you are looking for.  String To Byte Array and then Number To Hexidecimal String followed by a Concatinate String (which will combine the array of strings into a single string).
Message 4 of 8
(5,964 Views)
Accepted by topic author User79
See that red dot on the Number to Hex String function in the code image, that is your data being blown up into an array of U64.  Yuk.  Slip a for loop around the number to hex string function and it actually goes a bit faster.  Goes against the grain of everything you think you know about LV, but this is one of those exceptions.
Message 5 of 8
(5,945 Views)
Hi everyone,
Thanks for your quick answers. I have been running the attached solution and it works fine. Was that what you were recommending me to do?
User79
Message 6 of 8
(5,862 Views)
That is what I was suggesting for a bit of a performance boost.  Ditch the string length and just let the autoindexing handle setting N.
Message 7 of 8
(5,846 Views)
Thanks for your anwswers.
User
Message 8 of 8
(5,806 Views)
